The pre GMAIL app wont sync , it stays on SYNC screen for ten minutes or more. Whats going on?
I think the Samsung windows option would of been a better choice than this confusing slow phone.
Also when i updated the new Android version i lost a few options such as GALLERY for photos.
Not a greta phone choice so far.
The APPS are very limited or do i need to search somewhere other than GOOGLE PLAY?
Have you updated to the latest Gmail application? Have you tried to sync the inbox both with Wi-Fi and 3G mobile network?
The Gallery application changed name in the update so you should find it under the name 'Album' instead.
