Hi, I have a Xperia U by a little over a month and I like it really well.
A few days ago, while he was turning off it freezed so, probably making a mistake, I removed the battery and from that time it doesn't work. This morning it gave some sign of life because, while yesterday would not turn even a small light, when I attached to the PC is switched on the red LED, which remains fixed.
I wanted to know if there is a way to bring it back to life, or if I have to be to get it repaired.
Thanks
p.s. sorry fot the bad English, i hope you understand otherwise.
I tried to do it, but nothing..
I've contacted the support, and said to me to go to an assistance point.
Thank you everybody for all your answers
english please
repair it using sony update service.
I follow the istructions but nothing happens
Only the red led works
what error u got?
this should not be the case, try to plugin the mobile in switch off with volume down pressed as instructed and it should work always.
