Hey guys... I just bought an Xperia T (pretty cool phone btw), switched from my xperia ray. The headset MW600 worked perfectly with my ray, but now it seems like my xperia t doesn't recognize it.. and the mw600 can't see it either.. i even tried a master reset on both devices and still nothing.. please any suggestion or help would be appreciated
Make sure that the MW600 is set in pairing mode before you try to search for it in your Xperia T. You can find instructions on how to put it in pairing mode in the users guide.
http://www-support-downloads.sonymobile.com/mw600/userguide_EN_MW600_1236-6504.1.pdf
Thanks Johan. I already did that several times, but it's still not working, my xperia T can't see the mw600 no matter what i do.. i can still pair it with my xperia ray.. again i did a master reset to the mw600 but still nothing...
It actually works now.. thanks johan!
Message was edited by: cdgm
