Does anyone know if I can move pictures from my camera folder to other folders on my phone without having to plug it in to a pc?
I can select individual pictures but there's no option to move them to another folder
download this file manager https://market.android.com/details?id=com.metago.astro&feature=search_result
with this open the folder in DCIM>100ANDRO> tap and press on the pic u want to move and move it to the required folder
Great answer, this will definately help you achieve this task :smileygrin:
Thankyou so much!!!
yahooooo
anytime:smileywink:
thanks jake :smileygrin: :smileyblush:
No problem :smileygrin:
