I turn my 'data access via mobile network' on, but nothing happens and I get NO internet connection.
There is no problem with my provider, and my wifi at home still works.
I 've had this problem yesterday and now after downloading the new version of android, the problem is still here.
Anybody ideas??
try to enter them manually
google: apn settings android __name of your network__
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:[email protected]
Password:CINGULAR1
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
MENU -> Save
go to settings -> sony ericsson/Xperia -> internet settings
downloaded setting via wifi
but mobile data still doesn't work.
this might be a dumb question, but do you have a data plan?
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Password:CINGULAR1
Server: leave blank
MMS Port: 80
MCC:310
MNC:410
MENU -> Save
yes i have, 2G a month.
i checked, it's still valid and enough
it could be a network issue or the apn settings, try my suggestions above to enter the apn settings manually
i did what you said and then saved it,
but it just disapears and i can't check it anywhere.
is it possible that it's a hardware problem?
i checked the APN list of my country and found the problem.
it was like uliwooly said, but with other enteries
thank you both very much!!!
Anytime
