hello ! i have got a quest. xperia go says "There're five capture modes to choose from: Normal, Scene recognition, Sweep Panorama, Sweep Multi Angle and 3D Sweep Panorama" but in my xperia go i cud find only 3 (1. auto 2. normal 3.sweep) ..
u know y is tis happening?? plz help
any solution 4 it ?
sadly there isn't
You can try to use old GBs camera app. Not shore if it will work.
I would be willing to overlook this feature since i only used it once or twice. That is, i would be willing to overlook it if the rest of the phone worked. I experienced hige problems with calls, notifications and freezing since updating.
Why was deleted in the three-dimensional camera in the Last Update
