i'm just wondering why my phone cant download a game that is 49.00mb but my micro sd card memory is 8gb and the free is 6.69gb why i cant download the game it says that "there are not enough space" why?
For your info, not all apps/games can be installed to SD card, that depends on whether they are supported. As for your case, if your X8 is running on official firmware, which is Android 2.1, it is not possible. Only Android 2.2 and above supports this feature.
Hi, suggest you check available space in phone memory. Apps/games are installed to phone memory and not SD Card.
hey gwhispererz, if the games are installed to phone memory and not SD Card how can i install it on the sd card?
ok so how can i install android 2.2 and above on my x8?
thanks
anytime
xperia play . hafıza kartını takıyorum ama telefon görmüyor kartı. nasıl yapabilirim ? yardım !
Hi, can you post in English? This is an English Support Forum.
