Hello friends, I'm using Xepria Neo with Android 2.4.4. I failed to find out the following in my phone. 😕 NEO
Can we store b'days, anniversary etc in contacts?
Where I can see my memory card data? i.e. what's stored in my memory card?
From Android Mkt, apps directly gets installed or I can find their setup file?
How can I select default storage as Memory Card for all my photos, videos (captured by camera), for files (transferred via bluetooth) ?
I added my google account and by mistakenly click on SYNC PICASSA ALBUM, and my phone has synced it. I do not want my picassa album to appear in my phone's gallery coz my picassa album contains lot of pics and some vulgar pics too. How can I un-sync it?
Thanks in advance!
nah no luck
i also have 2-3 pics of the picassa..
RESPECTED SE Moderators,
Where are you? Kindly Help US! 😕
I have seen some video on Youtube about HTC desire in which there's one CHECK MARK option beside every sync content like album, content calendar etc. So one can easily UNCHECK it but I can not find it on my Neo with Android 2.3.4 😕
there are checkmarks..
but i cant find the same for google account..
you can select whatever you want to sync with facebook but not gmail 😐
go to settings > accounts > tap on your gmail account and you will see the very first option of picassaa..
there're no checkmarks, i can not find any.. look below at HTC screen-shot what I'm talking about.. look at checkboc circled in red beside sync symbol.. screen-shot is of Google account..
and below are the screen shots of my Neo of facebook & Google accounts..
you can see, there'are no such checkboxes to check and uncheck. my gallery is flooded with my lame picassa album. help anyone? 😕
can you search the memory card for the images..?
if you find that i will tell you to hide them..
just search for the folder , and let me know if you find it..
Finally, I got this shitt after some abstract trials.. Simply Follow this..
Go to Seetings> Application> Manage Application> All> search for GALLERY> tap it> click on Clear data and it's all done
Google account synced albums will be kicked off.. Good feelings..
Nice
make sure automatic sync is off
Yeah. that's obvious. I'm not that rich man :smileygrin:
