A huge number of popular apps are malicious and steal your details. Be careful.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
Yes it is bad and as bigf28 said You can block the permissions or just uninstall these apps.I saw the list and found that I use none of these apps
Please Mark
Thanks for sharing Arnab
No problem.
Those apps are not exactly malicious, they require some permissions which most of them are well known. Yes some of those apps can be considered high risk, but also they need those permissions. If you want to block some permissions you can use an app like "LBE Privacy Guard" or "PDroid Privacy Protection" (ROOT is required)
well said, but still passing on a number to a third party is bad.
me neither, was thinking about using the talking apps..:smileysad:
Never used them they are not good anyways
