My phone is crashing, it cant connect to google play, and the screen is unusually brighter and then, it goes like 30% of bright of its use, can u guys help me out? (disabled auto light sensor)
Repair your phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
Repair your phone
Bridge (for Mac)
Thanks it worked! :DD by the way, how do i know if my xperia is fully secured for the underwater? i wanna take some photos in the pool
make sure to close all the flaps and make sure that you close them properly, I don't have the Xperia V, I have the Xperia Z and you have to close the top part of the flap first then the bottom then again the top to secure it properly
Do you have any taskillers or task managers? battery apps? try while using wifi.
Taskillers/task managers=no battery apps=absolutely no! and actually, the download fails using wifi, i have 1589 songs, gracenote only give me 300 songs with info updated :L
