i have 400mg lost space on my internall storage
for example if phone shows 1gb free space when i connect to pc it shoes 600mg free space
i cant find anything that cause this diffrence...no hidden thing..no system protected or system hidden thing
any idea??
Could it be only app data?Maybe facebook,chrome.others?
so if they are app data why phone dont calculate them??..also if i clear those apps data the difrence will remain the same
a solution i can find till know is factory reset..but it will return with exact 300 or 400 mg lost space
If you go to settings-storage,can you clear cache?
Get the app Es-File explore. then click view and sort it from most space to the least, also one the left hand side, turn on the hidden files. Delete the file which has the most space, usually it might be like the others have said a cache file. Also,The data of cached files will come as misc files Danial, it is hard to view it on the settings as it only shows your app data and will not specify what actually uses that space.
CarbonoAtom
nope..i have no options
also setting>apps>all there is just"storage capability" with no options
@carbonoatom
no avail
i cant find any file that i cant see on pc
also es-explorer tell me i have 1.2gb free just like phone say..but pc say 800mg
There could be an issue with the files the PC sees and the phone sees.So in settings-storage,you do not have cached files?
@alexdon
yes i found cached data..its 183mb
if i perform factory reset at the starat i have 5.2gb free space..but after time phone and pc goes in to 400mb diffrent
@3xperia
yes i mean mb
what that app will do?
