i have 400mg lost space on my internall storage
for example if phone shows 1gb free space when i connect to pc it shoes 600mg free space
i cant find anything that cause this diffrence...no hidden thing..no system protected or system hidden thing
any idea??
Just tap on cached data,it should clear it.
the result is it
I'm not sure but i think this has to do with reserved space. About 10% or so is reserved so that you don't fill the phones memory completely. It's the same when i check an SP here. If i look at a Z1 which has more memory the difference is even bigger (still about 10%).
so if this is a reserved space then after factory reset it must have it as well.right?
but after reset to factory free space are the same on pc and phone
thanks to all of you
yes maybe its a reserved space and honestly i didnt notice that diffrent beetwen full sizes "5.8 and 5.4"
