do you have smart key app?
Do you have a pattern lock or pin lock or password lock?
It is related to smart key(it should be at least).Remove it.
I have a similar problem with the lock screen. I use a pin lock with six digits caused by an added active exchange sync. After that was installed I have no chance to add widget to the lock screen. I use smart connect to start the walkman but this will not show the walkman widget after power clicking. The second activation of power will show the widget of the walkman at the correct position.
The positive change of the last version (201) is, that the system do not stop, when I change the lockscreen from showing the date to the walkman widget after the first activation with power on.
