m trying to connect my one day old Xperia SP through hotspot to my laptop.
m using ecnryption WPA2 PSK. If connects with limited access. tried with both 2G and 3G network and restarting the phone and every possible option,
still no luck.
internet works fine in phone. can anyone help.
Topic was edited by: Rickard
So if you connect your phone to this computer using a cable tethering works? In that case i recommend that you check the IP-settings for your computers wireless network card. This is usually done from Control panel -> Network connections -> [properties for your WiFi-card] -> [properties for TCP/IPv4]. Here check that it's set to automatic IP and DNS.
First make sure with your operator that your subscription includes support for tethering. You may also need to change the internet settings in the phone for tethering to work. Go to Settings -> More -> Mobile networks -> Access Point Names -> [your internet settings] and check with your operator that you have correct settings here for tethering.
As mentioned above APN settings is fine and internet in mobile and through USB tethering works fine in same laptop.
my operator support for tethering.
is there anything specific to sony xperia tethering APN configuration that is required to be checked from operator end?
Thanks a ton Rikard.
its works superbly after setting automatic ip and dns for IPv4 and IPv6
I have a Sony Xperia SP. i am trying to use it as wifi hotspot. I connect the laptop to my mobile through wi-fi. The laptop gets and IP address. Althought connected to my mobile the laptop shows message "no Internet aceess". I am unable to browse any website.
I change setting in mobile to 2G mode and it works fine , my Laptop gets IP and I can vew sites. But in "WCDMA(preferred)/GSM" mode it doesn't work.
Please help.
Regards,
Shashi
Thanks a lot.. It worked. I know its an old post but i really needed to thank you.
I just changed the APN to the other defualt one which was already there and it worked like a charm.
Its very simple cause I have just had the same problem with my Sony experia 64. Just go to Settings >Mobile Networks > APN settings then ignore the already installed settings and set up a new APN according to your service provider. Then make use of the new APN.
