well i use illumination bar app.
i disabled every lightning effect from phone setting and let illumination bar app
do the effects that i choose for every kind on action, like text message, facebook, email....
it works flawlessy.
@SarahES let me know if it works for you
@SarahES wrote:
Hi guys. Has anyone noticed, after updating to. 205, that the light effects don't work properly when the phone is locked? I have different lights for different things (I.e. Blue for text, red for missed call, white for email) and when my phone is not sleeping the light colours are correct, however when my phone is locked/sleeping, the lights for all notifications are white. Have I missed something?
At the moment there are only two solutions to this problem, but they require root.
1. http://forum.xda-developers.com/showthread.php?t=2438012 ------- me not verified performance.
2. You must install the Xposed framework and install module https://play.google.com/store/apps/details?id=com.gzplanet.xposed.xperiastaminaled ------ tested - works
