Hi,i have a question...how can i make,if it`s possible, my illumination bar work properly if the stamina mode is activated? I tried to find an option for this in stamina mode but i failed...can anybody help me please?
https://play.google.com/store/apps/details?id=com.rundgong.illuminationcontrol&hl=it
and add it to the stamina mode exception.
you're welcome.
It is not possible,stamina mode disables any light notification.You can try to add an app as exception,but most sure it will not work.
you're welcome.
Thank you
you made my day
