Hello,
anyone else experienced problems with the LED notification?
Here are some problems.
It only does flash very shortly etc.
No Costumization in the option menu
Thanks in advance!
customize it how? color? no, the only thing you can do is open the messaging app > menu > settings > notification light on/off. Just like with 2.3.7
how about taking advantage of that hideous transparent bar at the bottom?
SMS/MMS &/or Missed Calls notification bar light
http://talk.sonymobile.com/thread/41079
is the build in function gone? i am not that great app user, especially when it only adds functionality that was already implemented
that option to use the transparent bar as a notification bar wasn't implemented,
remember that one of the great things about an smartphone is the market, so you can customize your phone as you please.
which functionality are refering to ?
sorry i formulated it wrong. surely the use of the big bar with illumination is nice, but i found the LED very decent and liked it much. As i remember i was able to costumize this led in the settings. This functionality is gone.
k thx for your help!
Anytime
