Hi folks just wondered if sony has plans to bring android 4.4.4 to the xperia t3 and if so any ideas when.
We are unable to answer such questions and have no influence to be able to acquire the answer - You need to contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
4.4.4 update is now available for Sony Xperia T3
Please tell us your experience if you update your Xperia T3 to android 4.4.4
Sony with this update has activate the option move to sd card.let us know if you get the updade and wich country you are.
http://www.androidauthority.com/sony-xperia-t3-android-4-4-4-579426/
The update begins for several countries. first i think is on india or philipines and then come to other countries.it is no for sure when the update come for your country.I live in greece and still no update.i am justy waiting.if sony could tell when ariives in our contries will be cool.
