Sometimes when I need to write a text or Google something I can't get the keyboard to appear
Have you turn your phone off and on again lately? Try that if you haven't..
If the problem persists, clear data for Xperia keyboard. Go to settings > apps > all > Xperia keyboard > clear data. Restart the phone. Try again.
I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
HI! I have just lost the Z and the S key. When I press Z I get an X and when I press S I get a da. I've done the clear data and it doesn't work. All other keys work normally. Thank you.
My keyboard is not workin' properly. Did someone had it solved???
I am facing the exact same problem, the keyboard does not appear at all. Yesterday my keyboard stopped appearing and I've done everything i can think of to get it to work, ect turned it off and on manually, cleared all cache and data, left it off for a few hours. I'm completely stumped as of what to do.
Thanks
