I have checked in the forums and in google but could not find a clear answer.
I would like to ask if it is possible to connect and use a usb keyboard or mouse to a xperia ray without a docking station (with a micro usb to usb convertor).
If yes does the manufacturer of the keyboard or mouse matter (compatibility issue).
Also is it possible to connect a keyboard through bluetooth.
Thank you in advance for your answers
not it's not
Thank you for your answer.
anytime
see this:
http://mugur-ionescu.ro/diy-connect-a-mouse-and-a-keyboard-to-your-xperia-arc.html
it should work with Ray also
