I can't browse in my phone using the letters. The letters that appear are russian when pressing my keyboard
No matter what language I switch to in contacts when pressing a roman letter the options are in russian
I have tried both types of reset, switching the languages around but nothing
Have you tried changing both the Phone and Writing language?
One thing you can try, is from stand-by press: left--0000--right (using your milti-directional keypad and four zeros) and see if that restores the default language.The other thing is to select the As on SIM setting under Phone language.If all of this fails, since you have already tried a reset, I suggest you run the update service:
http://www.sonymobile.com/gb/tools/update-service/
Hope this helps
Oh and I forgot I changed the language in contacts from # still nothing
Hope this helps
The left--0000--right thing did the trick. Thank you
No worries.
