im looking forward to buying Sony Xperia Sola and i would like to know if the battery is replaceable or not
expecting a reply very soon
thank you
I sincerely don't know if you can find battery paks yet. But you can replace it yourself. It just takes longer and some tools
You can't replace it by yourself without losing your warranty.
tnx for the reply
so lets say after the warranty will i be able to buy a battery from a local store?
or should i vist an service center to get it replaced? i dont know weather a service center is located in my country to be honest x.x
thank you very much for your help solving my problem :smileyhappy::smileyhappy::smileyhappy:
guys i found 3rd party battery replacment with double capacity for our sola at ebay? price arroud $15 how do you think?
the 2680 mah one? i dont think so sola uses Li-Ion 1320 mAh
there is a huge diffrence there ijs
I would be nice. But we can't confirm that the battery actually fits
replacing will void warranty ..
Can you please post the ebay link for the battery you purchased?
