Hello. I want to know is SanDisk Mobile Ultra is compatible with Xperia Mini Pro?? I want to buy 16 GB of this.
Thank you very much!
hi @blackvista the SanDisk® Mobile Ultra™ microSDHC™ memory cards supports by mini pro as your willing to buy a 16gb sdhc card I would recommend you to buy a class 6 16GB.. dont forget to mark my answer as correct and helpful
if i am not wrong ,mobile ultra is not supported by mini pro
@nabeel he is buying a 16GB which means it's the SanDisk® Mobile Ultra™ microSDHC™ memory cards...which is sdhc so it's support...but if he is gonna buy the 64gb it means that is sdxc..which won't support all cards upto 32gb is sdhc so there's no problem but I would recommend @blackvista to recheck that you card is sdhc..
