reverse teethering force closes every time
is your phone rooted?
its better to use Connectify Me
i would have suggested that if you asked How to connect to internet through wifi..
usb is better or wifi
you can only use the connectify or virtual wifi router if you are running windows 7,.
the reverse teethering only works if your phone is rooted.
well I think I would choose wifi.
thnx
