I have enabled the data. But i am not able to connect to any internet. Is there anyother option I need to check ??
recall , what apps did you install 2 days ago, ( any other changes ) ,, try uninstalling them
or do this
settings> privacy> settings reset and after that download the settings again by following above procedure and see if it works
make sure you have the settings/ correct APN
settings> sony ericsson> internet settings> accept
let us know the result
I was using the internet before its not working just therse 2 days ...
I have verefied these setup .. it looks fine...
atlast i restored setting
now its working fine. :smileygrin:
thanks for the help
thats great
no problem
enjoyy :smileygrin:
Don't forget to mark the Correct Answers and Helpful Answers
I am having 1 more issue.... that problem is repeating...
i am restarting each time for connection to internert...
wht would be the problem...??
some app
most probably
do a factory data rest and then again download the settings,,
don't install any app but observe for sometime if the problem exists
