I have a T2 Ultra, so this is what you could do
If you don't use Google+ and other preloaded apps
settings > apps > all > G+ > uninstall updates > disable it (this last step is if you don't use it, it won't increase the internal storage) > repeat with any other preloaded app that you don't use.
also, move all the pictures, videos, music, download, bluetooth files to the SD card, if you use whatsapp, use the file commander > whatsapp > copy paste the folder > move it to the SD card > then access the whatsapp folder on the internal storage and delete the media folder or the items inside, pictures, videos, recordings, you already have a backup and it will free up storage.
