I connected my phone via USB the other day for the first time, simply to charge it as my charger was upstairs at the time. When it was charged, I noticed that my songs were missing, as were all the files in my gallery. I have an SD card in the phone, and files from my previous phone were saved on there. All photos taken with my Xperia were saved on the internal memory for some reason, and they're gone too.
I can only see my old phone files on the SD if I use an SD card adapter, I can't see them on my phone gallery, or using the USB linked to my phone. When plugged in via USB, the laptop tells me my SD card is full but when I click on it, it is empty.
The only way I can view the new photos taken with experia is through the file commander app. Why is this? If the app has them, then there must be a way of recovering them.
I've cleared my gallery app data, and tried taking a new photo on my phone. It stays until I restart my phone, and then everything is deleted again. I really need some help. I want to be able to view my old and new photos without them being deleted, also after that is fixed, can anyone tell me how to make my experia save my future photos onto the SD card instead of internal memory?
Thanks in advance.
Thank you. Will using this program delete all of the data saved on the SD card and will it fix the problem with my images on the internal memory not showing up as well?
Just great,I am glad!
