I had Xperia mini ( ST15i ) Has overheating problem as soon as I turn it on and it happens always and every time .
My question is " Can I install ICS while my phone over heating ? And " How it is done ? Do I update while phone is turned off although capacitive buttons still interfering ? "
you can update to ICS (if your SI number is on the list), instead of PCC use SUS
unrelated topic, if you have some time please check this thread
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
-=[ Thanks A Lot ]=-
And yes my SI is on the list . So I update using SUS with the phone turned off and choose second option " Reset + Update " .
I hope ICS solve the problem .
Keep us updated
After I update my phone to ICS the way I said before , it still the same problem as soon as I turn on the phone the capacitive buttons are triggered continuously very fast I cant even unlock the phone or load home screen .
I am very sad ICS didn't solve my problem
take it to a sony repair center
Update !! I am now so happy , I finally get red of the problem . it was too weird , but my brother figure it out , It was not overheating as it happens when the phone is cool and as soon as the phone boots up , It was software problem made function of capacitive buttons being inversed , so when you don't touch the button it act like you keep touching it . and when you touch it and keep it touched it act like it is untouched . So after booting I kept cancel button touched until I make it to factory reset option and I used it . After reboot problem solved .
-=[ Thanks A Lot for Your Big Help
Factory reset + update was a good choice
Enjoy your ICS
I did choose Factory Reset + Update as you told using SUS but problem stayed , until I did Factory Reset on the phone .
-[ Thanks ]-
