i have a idea for improving xperia p battery.maybe it will help u.
Remove some internal app(if ur are rooted) or disable app.
1.Weather-widget (install another from play store) it will improve battery 7%.
2.PlayNow
3.LiveWare
4.Recommender
5.News&Weather
6EA & Foursquare(minor)
if u want u can remove more.
sorry for my bad english
Sorry bro. i don't use FB ,so no need to disable it lol.i ply game on my xperia p.NFS MW ,Tintin,N.O.V.A, about 7h a day .sorry for my bad english
if you don't use it you MUST disable it as some of its add-ons will run in the background
Tnx u.glad to u helping me for relocking BT.i am now very happy:)))
anytime
