i used to play games on GB n theres nothing wrong all going smooth, but after using ICS i cant play it. eg: asphalt6 or street fighter 4 (after a moment it FC, it has weird graphic or artifact) is there anyway to fix it?
there isn't a fix yet nor an official statement on this
i guess i have to go back to GB n wait for a fix or wait till die on official fix :smileysad:. btw thanks for quick respon
Look in your phone settings menu for a setting about "hardware acceleration"; is there any improvement if you change this setting?
already tried it but no luck
I've got a more-same problem - the phone gets 50 degrees when i play fruit ninja! Need to cold in water after that. I tried to go back to GB, but no success. Now I still have unlocked ICS, and I can't reinstall it, 'cause PC Companion says the phone with modified software. I have also low FPS in videorecording. Not only when recording, but even when just playing the video.
already go back to GB, but with custome GB rom. since u have unlocked bootloader u can choose 1 of those great custome rom
Could u please give a link to any GB custom rom? Or tell a name of a good one. Thanks
I would wait for CM9 to be ready with linaro, in the mean time this is how to downgrade
http://talk.sonymobile.com/thread/38251
