HELLO,
my friend and I just purchased sony xperia s handset. She upgraded her phone to ICS while i havent. After the upgrade, she is not able to download from the play store or the browser. She is using 3G. When she tries downloading, it just gets stuck to downloading.
if we follow this
Settings > apps > all > google play store > clear data
will all the apps get deleted too?
and what if nothing happens? should she downgrade it?
please help.
i m hesitant to upgrade because of this issue. but i really want to upgrade it without such problems.
please guide.
I am also unable to connect to the Play Store since upgrading to ICS on my Xperia Arc S.
What is the proces for this restoration to factory presets?
