Dears,
I just got Tipo Dual and I'm using to SIMs, one is a line with no limit on calls and the 2nd one if from my company, I have only 130 free minutes .. is there a way to know how many outgoing mintes did I do from the 2nd SIM?
In old sonyericsonns mobiles, there was option of counting outgoing calls but I can't find it in my new mobile
Help me please
Noha
As I understand there is unfortunately no such application or option in the phone as default. I suggest that you check on Google play store if you can download an application for this.
Dear Johan,
Thank youf for replying. I already tried many applications but nothing show timer for both SIM's ... if you have any sonyericcson mobile around you, check in Settings>Time and Cost> Outgoing Call
You will understans what I want exactly and hopefully you would be able to help me.
Many Thanks
Noha El Sadr
