hi I cant save or edit my contacts or add new ones the phone lets me do it then 10mins later its back to the un edited version or just removes the newly added contact.
many thanks
This is due to the synchronization function activated by you. If you are using any sync functions like Google sync then deactivate it. If you need to use synchronization function then synchronize your contacts from your phone immediately after an edit.
Thank you looks like it is working
