i was trying to reply to my friend in chinese but was not able to change to chinese input. How do I do it?
Try long pressing in the input box and you should then get a popup that gives you the input method option, select that and select chinese keyboard (X10 biggun)
Hi Suze,
Thanks. U are a great help...
She is indeed.
You can also use the Chinese handwriter input. It is less taxing on my big fingers, alays tying so har to land on ONE key.....
