I do not use facebook but everytime I when I look at my running apps it seems to be on. I clear the data then it stops. However after 5 mins it restarts any suggestions?
Thanks for the answer. Maybe with ICS I can disable it but who knows when that is available:smileylaugh:
You cant. FB always will restart. I tried everything but it always restarts.
Yes you can disable it with ICS. Please mark the correct answer if your query is solved.
