I have updated to 4.3 and some times I mistakely touch the Camera icon on lock screen. So I want to remove it from lock screen.
I have Xperia SP.
You should be able to disable the quick launch open from the lock screen if you open the Camera application > Press the menu button (three vertical dots) > Tools tab > Quick launch > Off.
You can also download an application that controls the lock screen. For example, the following one:
https://play.google.com/store/apps/details?id=com.wordpress.chislonchow.deviceadminkeyguard
