In my in Sony Ericsson J108i Cedar, I am unable to erase the Log In User IDs that I have used in web sites which I browse in this mobile.
Please help me. Thanks.
Thanks for suggesting to click the TAB. There are tabs in the Internet Settings. I clicked the TAB and found the CLEAR COOKIES - CLEAR CACHE - CLEAR PASSWORDS - CLEAR ALL HISTORY options. I cleared them all. But the EMail ID that I typed while logging on to my email account appears again if I type again just the first two letters of that ID. That ID also appears while typing SMS as Word Suggestion. I found the WRITING SETTINGS while writing new text message for sending SMS. In this settings there are MY WORDS - NEXT WORD SUGG - WoRD SUGGESTIONS options. Under MY WORDS, there are the words which I entered using SPELL WORD and the ID under question is not found there. If I switch off the NEXT WORD SUGG and WoRD SUGGESTIONS, that ID does not appear. If I switch on again the NEXT WORD SUGG and WoRD SUGGESTIONS, that ID appears again. Will it be stored in MEMORY CARD? If so, is there an option to erase it without formatting the Memory Card. Dr. Chris, Kindly suggest.
Main menu--Internet--Options--Advanced--click to the Other tab--Clear Cache/Cookies/Passwords.
Thanks, Dr.Chris. But, in Sony Ericsson J108i Cedar after clicking Main menu and Internet icon you are taken to a green colour web selection page wherer there is no OPTIONS button. I also tried main menu-Settings-Connectivity-Internet Settings and thereafter no OPTIONS button. Please help. Thanks.
Yes, I have the same green coloured webpage on my W995 and the Options button should be the top-left soft button which is there whether you are just simply on that local web page, or actually browsing the web.
While I thank you, Dr.Chris, I would like to mention that I still need your help as no one else is answering my question here except you. Sorry for the trouble. In the green page, on top left, there is no soft button. Even after browsing FACEBOOK or GMAIL, I dont find that button on top left. It may be available in your W995. But where is that option for J108i? Please reply. Thanks.
http://dl-www.sonyericsson.com/cws/download/1/835/750/1296738239/J108i-J108a__UG_EN_1241-2576_2.pdf OK, so what options do you have (what is available on the left, middle and right buttons) when you're on a web page? Have a look on p45-48 of your manual regarding the web browser toolbar.
Yes, Dr.Chris! Thanks for the PDF.
In the green page, if I click on the spanner icon, I get Lense-Pen-Star-Down Arrow.
If I click on the STAR, I get another menu:
EXIT BROWSER- LANDSCAPE-REFRESH-SEND LINK- ZOOM- FIND ON PAGE - SAVE PICTURE- MARK & COPY- HISTORY-SETTINGS.
If I click HISTORY, I get the names of the sites viewed with a TRASH BIN icon at the bottom left to delete the chosen Web Address.
If I click the SETTINGS menu it takes me to the Mobile Phone's Internet Settings area where there is a menu either to allow cookies or not.
But where is the CLEAR CACHE menu option..?
Kindly guide me.
Clearly, the web tool on your browser is entirely different to the one on my phone.I can only suggest you go through all these options and look for any tabs (by clicking right/left) in the sub-menus, that allow you to clear the cache and/or passwords.
It sounds like you've tried all options there is. I just had a quick chat with my 2nd line on this matter and we did some testing.
The phone will create a "my words" list for each input language so if you e.g. add a new word to this list when typing with the English input language it will be saved to the English My Words. If you at this point switch to a different language and check the My Words, you will not find this word here.
So, what I'm trying to say: Change input language (press and hold # key when typing) and check the My Words for each language to see if you can find it here. Do this even if you've never changed input language before. The phone might have saved this word to the wrong list or something. I have not heard about it doing so before but it's well worth a try.
Let me know.
