i accidantly press factory data reset and all my phone contact gone pls tell me how can i recover my contacts. my phone is xperia s.
Did you have them sync'd to a google mail account, Saved to sim card or did you do a data backup using PCC if not then i'm afraid i'm out of ideas and probably you have no chance of recovering them
No way, your contacts are gone!
I'll try and be a bit more helpful than the last post
The safest way to back up your contacts is to have them linked to a google account.
I find it also helps because I can check my e-mails, and update my contacts on my PC rather than on the phone, same with google calender.
Hopefully you had them linked, then it's just a case of logging back in and re-syncing. They should all then re-appear.
If not, then maybe your loss is someone elses gain, somebody reading this thread will realise they've not backed up their contacts and need to do it :smileygrin:
In my view, if you would like to recover deleted Sony phone contacts directly. You can use some android tools. To choose a professional tool is very important for us. Because we can more easily solve our problems, The professional tools capable of handling more specialized.
Sir, my phone is auto synced with my gmail account, now i don't know how to recover the contact, please help.
To restore a backup of your Gmail contacts, first you should go to your inbox and select “Contacts” from the dropdown menu of Gmail, then you need to click "more" whether you see your contacts list or not. Finally, choose "restore contacts" to get your contacts from your Gmail account.
I had backed up my contacts with pcc but even then i am unable to recover my contacts. Its unable to recover all of my contacts as some some of them are not vissible to me.
I think it is not complex ,the contacts can't complete deleted from phone memory once the contacts are deleted by you , you should find an effective recivery tools to get them back from android phone ,
