repair it with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Official, I don't know but un-official you can do it by Flashtool.
Follow this http://talk.sonymobile.com/thread/34424
seem like downgrade need to do many things LOL~!!!!!!:smileyshocked: but i will give it a try ... if i fail the step =.= my sony xperia s will become brick ???
For offcially downgrade you need to visit sony service centre or else use flashtool.
It looks more dificult than it is. But if you're afraid or you're not very fimiliar with windows and computers than don't do it.
- Download flashtool and update here http://www.xdafileserver.nl/index.php?dir=Sony+%28Ericsson%29%2FSE+Xperia+S+%28LT26i%29%2FSTOCK+ROMS
- Go to link above and go to GB folder. Download firmware you want. for example LT26I- CE1 or LT26I Generic NL or pre-rooted ones.
- Install flashtool and update.
- unzip firmware in "firmware" folder of flashtool. C:\Flashtool\firmware\
- run flashtool. press flash and choose right firmware like LT26I....CE1 for example
- press OK, follow instructions.
- connect youre phone while pressing volume down.
- when flash is done, unplug phone and press power button. Wait a few minutes.
Watch tutorial here which is almost same as Xperia S http://talk.sonymobile.com/message/172487#172487
This link may describe it better and show you just how easy it is http://www.xperiablog.net/2012/03/26/debrand-your-xperia-s-tutorial/
If you need other firmware then I have quite a few on my Google drive - Leave a reply and I'll add the link to it
How to manually update 2012 Xperias to android 4.0.4 & downgrade
http://talk.sonymobile.com/thread/41609
Nice tutorial
today i just wan to flash my sony xperia s =.= '''' but the logs say plz make sure you are not in the mtp mode .... wat tat mean
Flashtool will work just fine
