I recently upgraded from Android Gingerbread to ICS. However, I do not see the Face Unlock feature under Security>Screen Unlock.
Anyone can help? Btw, I'm from the Philippines! Thanks!
install flashplayer from the market and then look for it
Turn off and wait for 2 mins and then turn on.you will find that option.It worked for me ,but.
Face unlock was disabled....:smileysad:
i have flashplayer(Adobe) insatlled.but still my face unlock s disabled.
open flashplayer and then restart your phone
i tried that now..still same issuse.by the way adobe flash player 11.1 i am using..
do i need to install anyother flash player
After installing you restarted the phone? if not please do
i restarted 4 times still same issue
how about repairing the phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
My issue has been resolved after updating my Adobe Flash Player! A million thanks to uliwooly!
Face Unlock feature is now showing up on Security>Screen Unlock and I am using the feature now!
Great job!
