Is it possible on an Xperia X10 Mini Pro to delete multiple texts at the same time? If so how?
Thanks.
If you are talking about multiple texts within a single conversation there isn't a way in the stock app but you could try something like Handcent SMS free from the market which allows you to do Batch mode and gives you a tick box beside each message.
Thanks Suze; I've installed Handcent SMS and all is well with the world 🙂
