Multiple numbers for contacts?
I have just bought a Sony Tipo. My old phone was a Sony Elm. I transferred all my contacts off my old phone onto the sim, then imported them from the sim onto my new phone. On my old phone I used to be able to click on one contact name and see their mobile, house, and works numbers. On the Tipo I can only find one number under one name unless I click on edit and then I can see the other numbers there. How can I see all the contacts numbers on the Tipo? Is there a drop down box so that I can select what number to phone a contact on?
Cheers, Dave.
Actually it's the same thing for Sony Xperia Tipo. When you open a contact you should be able to see several numbers for example: Home, work, fax etc.
But if you only see more numbers right after you have selected edit contact, then it's not created the correct way.
Try create a new contact and select "Add field".
Maybe something happened when importing the contacts.
Let me know if this solves the problem.
Thanks for your advice. I thought I was doing something wrong but it looks like you are right. I put in a contact manually and selected Add Field to add abother number for that contact and it works. Thanks for your help. I have been trying to figure this out on my own for three days!
Cheers, Dave
You're welcome, have a nice day!
