I woke up in the morning and turned on my phone
and a screen pop up and says:
The application Sony Ericsson Home (processcom.sonyericsson.home) has stopped unexpectedly. Please try again.
and there is a button says: force close
when I tapped that button, it shows this on my screen
It still able to connect to my computer, to update the andriod software ( I just updated to the newest one 4.2 something to just to see any hope that could fixed my phone)
but I can't call, can't do anything from the phone, can't even go to setting.
I saw some of the post that people were having the same problem, and I had tried all of them,
but it doesn't work....
I got this phone in august, when the phone just came out, and it was perfectly fine before the day I was using it.
Please help me =[
if that doesn't work then use Update Service (remove both SIM and SD card before hand)
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
don't forget to mark the Correct & Helpful Answers
1st take off the battery and w/o it press and hold the power button for 5 seconds, put the battery back on and turn it on, if it doesn't work then
on your computer go to
market.android.com sign in look for taskiller
click on install, your phone should download it soon after, drag the notification bar down open it and kill all the apps
thank you so much for helping me re-set up my phone,
the phone is fine now
it just sadly I have to use the update service
every all my contacts are lost,
but oh well, at least my phone is fine now
For future reference
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
