I can't create folders in App drawer, But I am able to make it in the main menu.
Is there a way?
To create folders in the app drawer you need to sort the drawer after "Own order". To create a folder tap and hold on an app and then drag and drop it on another app in the drawer.
Dear Rickard; Thanks man!
It was so easy!
I gave you one kudo
That works only in the Home screen and not in the app drawer, does it?
It also works in the app drawer with our launcher but the sorting in the app drawer must be set to "Own order" if you want to create a folder in the app drawer.
you are my godddd thanks thanks thanks a lott yuhuuuuuuuuuuuuuuuuuuuuuu
