Can anyone help with this, i try to setup the email. and this shows up:
HELP PLEASE.
btw the email app preloaded it's quite basic, you should look into K9 or Maildroid
you have to be more specific as there are different settings that you have to enter for each email account, you can googe: server settings android "email account"
Thanks, I downloaded the K9 mail. set it up in 30 secs.
Anytime
