Hi Guys,
I cannot get my flash player on my browser running.
I have dolphin browser, chrome and stock browser tried but are not able to use flash.
I have also installed adobe air, then set the browser flash enabled but no success.
I am running on Stock JB with Locked BL and Unrooted
Please help.
TIA!
I recommend using nothing but the latest version available on the site. Previous versions may have security flaws.
I downloaded mine from here (scroll further down and look for the Flash Player for Android 4.0 archives section), and installed only that alone (i.e. no Adobe Air). No issues with Flash content in Chrome and the stock Browser.
Thanks taboo5200,
which version did you use? Any of 'em?
EDIT: I'll try the latest release and report back when done.
This is to confirm that the latest version does work. But for the
website that I wanted to view, only stock the Sony browser
worked in compatible with the adobe flash..
This was the link I used to verify if adobe flash is working.
I tried it on dolphin and chrome, but it didn't work. Only the stock browser worked, AFAIK.
Thanks bro taboo5200..
In addition,
this is what it looks like with installed adobe flash using dolphin browser.
and this is how it should look like with the flash installed using stock browser.
So, thanks to taboo5200 again. :smileygrin:
