Btw i think its normal
Also check if auto sync is available or not it will drain more battery
Well, sounds pretty normal to me. There is a battery review here, but I don't think it represents real world use:
I never get anywhere near that - no way would I get 7 hours video with mobile data on.
I have experienced a heavy battery drain and it was causedby the google play services. Needed for nothing, but it ate that battery in one day. So, go to settings-apps-running...and disable what you do not need.
That will give you more ram and battery
