When I use any app my phone is get heated at upside. Pls Give me suggestion for fix this problem .
i am sorry, but sony does not provides us with international wrranty
it means if there lies any fault within your device, they won't repair it for free
however just get it checked at service center, they would see if everything is fine or not. ( free of charge)
hi
heating of phone while using apps, calling, gaming etc etc is normal ( its the cpu thats gets heated up )
however if its get toooo hot to hold it comfortably then you must get it checked at service center
It heated to much from few weeks n I can purchase this mobile from Oman can my phone is taken by Indian Service Centre.
Nabeel is correct, however regarding assessment by a repair agent you may wish to check with them first as some repair agents may charge an assessment fee for looking at the phone regardless of any repair being performed.
What are your thoughts about this forum? Let us know by doing this short survey.
I have the same problem of heating on my Xperia Pro while charging, calling, gaming, listening music. Will this heating of CPU can cause my phone any sort of damage and in such case whether sony will take care of its warranty?
