Help! i can't connect my phone to the android store powered by google play.
when i click "Install" of a app with my computer a pop-up message says that i have to connect my phone to the server by choosing the white shopping bag app icon in the phone's menu.
in that app i entered my e-mail address(which is the same address as this account) and password and then clicked "sign-in"
but after about 2 minutes it say's "Can't establish a reliable data connection to the server"
but i can surf through the internet by using the browser in the phone so it can't be a problem with my internet connection isn't it?
what should i doooooo?
p.s- my phone is xperia mini pro
Read this >> http://support.google.com/googleplay/bin/answer.py?hl=en&answer=190860
...just connect your phone to a stable internet, wait until the app updgrades itself, if it does'nt work maybe you can try this http://www.androidpolice.com/2012/05/11/download-latest-google-play-store-v3-5-19/
hope it works.
i still have android gingerbread (2.3.3) in my phone. (didn't update into 4.0.2.A.0.62 because some say ICS is not fullly trouble shooted). do you think that's the problem?
my android market version is 2.3.4
.62 it's NOT ICS that's just the build number
go to settings -> about phone scroll down and take a screenshot
Nabeel,
when i go to Settings > privacy > there are 2 options
1.factory data reset
2.settings reset
does the second option enough? or do i have to follow 1st option?
how to take a sreenshot
go with factory reset but make sure to backup everything but settings
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
if you have android 2.3.4 press and hold the power button > screenshot
if you have android 4.0 press and hold both power button and volumen down
