the problem ocurr when i have deleted some stuff from system/apps ,the problem is that al the mane for all contacs is there but not showing their numbers.If i enter phone end i start tipping a number the contacts with number is showing & can i call from agenda don`t , i will upload case 1 & 2.can someone upload ther files from their phone ?
You mean whenever you tap on a contact nothing happens ?
If yes then it means you have had removed "Infinite view" from your system apps
Download and send it to your mobile, change permissions and shift it to systems/apps
problem solved with apk from singapore firmware `73,the one from you noth working,buth tks for the ideea
